internationals version of the powerstroke
94f450sd
certified nutjob
plymouth,ma
here some pictures i took while replaceing the clutch in a 2000 IH 4700 2 car carrier.this bad boy holds 5 gallons of oil!
Patrick Feeley
Tehachapi, CA
You can retrofit that waterpump on our trucks (a number of folks have done so). There are a few threads at TDS on the conversion. Cheers!
Yeah, the IH water pump comes with a coolant filter head on it. Good idear huh?
What turbo set up is that Rich?
94f450sd
certified nutjob
plymouth,ma
thats bone stock international.best i can tell its the same as ours but no EBPV and the 99-up SD up pipe flange
The compressor housing looks different, we dont have that two bolt holed flange on our compressor? The backing plate to the compressor and the turbine exhaust housing looks like a Garrett 38, but that comp housing is different.
roosterdiesel
Earl needs B100
Amarillo,TX
Mike, that looks like where a wastegate acuator would bolt to.
How many bolts does the flange on the EX housing have? Is there only two bolts holding the non-EBPV housing?
