Question Which brand of Winch???
ponyexpress94
Diesel Power Junkie
Maryland
I am trying to select a winch to mount on my flatbed trailer. I have never owned a winch before so I don't know if Warn, Superwinch, T-Max, Ramsey, or Mile Marker are equal or if one is better than the others.:dunno The trailer already has dual Optima batteries to power the hydraulic tiltbed so I just need to choose a winch that will be capable of pulling on rolling vehicles or tractors that will weigh 7,000 pounds or less. Any help on build quality, performance, warranty issues, regrets:doh: , or any other things you have learned would be greatly appreciated. Thanks in advance.:sweet
patrickc
Ontario, Canada
I have had Warn, Superwinch, and Mile Marker winches in the past. I didn't have much luck with Mile Marker the motor burnt out after 6 months of weekend use on my wheelin rig. It wasn't a big deal about $100 bucks to fix. Keep in mind though it was constantly in and out of water on weekend wheeling trips.
I have had very good luck with both warn and superwinch but i think warn is a far better winch yet they do carry a much higher price tag. More than double.
I know several people with T-max 9000lb and 12000lb models and they are both turning out to be very good products at a decent price.
Hope this helps!
Cheers. Patrick
Hydraulic tiltbed
How is your hydraulic pump setup? If there is a way to plumb into it I would recommend a Mile Marker Hydraulic Winch. They are normally powered by your power steering pump but since you have a pump already on the trailer it only makes sense to use it for double duty. Hydraulic winches are far superior to electric ones. If you must go with electric I would recommend Warn.
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
The Summit winch is the same as T-max brand winch and cheaper. Its a good winch but has weak solenoids. Once I replaced them with solid state ones I've had no problems. I think the new winches come with the improved solenoids.
RoyBoy
Diesel Dork
central WI
I have a Warn 16.5 K mounted on my hyd tilt gooseneck. That would be more than you need but I will say that I've SKIDDED (all 4 tires locked up) a 16,000+ lb tractor up the deck with a snatch block (cable doubled back) set up :eek:
I'm sold on Warn, but I use mine pretty regularly, you may or may not need one that good ;)
