Help Needed Transmission problem
swampthing32
Elberton ga
swampthing32
2003 F350 4x4 crewcab torqueshift transmission with 6.0 . Just replaced trans becouse of previosly posted issue . Truck was scanned for any codes on both engine and trans prior to trans replacment with no codes . currently when truck is running and put in gear TOW/HAUL light comes on by its self and starts to flash , will not shut off when button is pushed . I will not drive truck on new trans yet . Trans is reman from Napa . any light on issue before i take to have computer flashed would be great .Thanks
You need to get the truck scanner to find out what is wrong. There is at least one transmission code, telling you what is wrong with the transmission. It should be in the form of T-0000 or P-0000 and the numbers will tell you what is going on. The shop that did your tranny should do this for you and fix the problem. Post the numbers here and someone will tell you that the code means.
