Question Top speed
Cabutt88
Central Illinois
Have a question we took our 2010 F-450SD out to supper last night we went to pass a chevy ran it up to 80 he sped up so i pushed it harder it seemed like the limiter kicked in at 83mph!!!!! that sucks tried it on the way home and had the same result anyone else have this problem??? we have a 2010 F-450SD 4.30 ratio auto trans.:dizzy
ponyexpress94
Diesel Power Junkie
Maryland
As you have already found out, the truck is electronically limited to 85 m.p.h. because the tires are only rated up to that speed. This is designed into the truck by Ford, and I am not aware of any way to eliminate it.
whipittire
connecticut
speed
the limiter is set at 85. when it kicks in its very smooth,just no more throttle response.i dont want to run my 9100 lb truck faster that 85.....do you?
`08 Blue Crew
Somewhere in the lower 48
I experienced the limiter once. A short time later the Check Engine light came on. When I took it to the dealer he told me it was due to me hitting the limiter. He asked if maybe I was out 4-wheelin and maybe spun the tires in the mud, thus hitting the limit. I said, ....yeah, that's it. I was in the mud.
As stated by Patrick.. the Speed Limiter feature is programed into the PCM, due to tire ratings, I think. My Quadzilla Programmer has a Yes or No option for: Speed Limiter ? Sooo.. I guess it can be programmed out. I chose Yes though, cuz I too think 85 MPH is also fast enough.. for my Dually anywayz.
:dunno
