Question The air dam under the front bumper
Dogman
tampa,FL
I was reading somewhere that the 2008 to 2010 had a change in the air dam under the front bumper. The 2010 had a longer one. It's was done to increase the mileage. Anyone know anything about it. :dunno
Fine69
Cranberry Twp,PA
The longer air dam actually started in late 08. I can't remember if it was a Job 2 or Job 3 change. It was done to improve fuel mileage.
Dogman
tampa,FL
I need to figer out how long to make one. Anybody give me some number on the 2010 air dam.
Fine69
Cranberry Twp,PA
I'm assuming you have the shorter air dam and want the longer one? If you were closer, I'd trade you mine! I'm considering cutting mine down to the shorter version because it looks better!
ducky1402
member
AZ
hmm very interested in this i have a job one 08 so im sure i would love to try out a longer airdam for milege :D possible to swap for newer air dam? done a little reading and called stealer ship part number 1 8C3Z 17626B is part number for job 2 and up air dam said usually around 100 supposed to be direct bolt up
