"Small" Diesel engines
Tman123
That One Guy
Murray, Utah
So I've had this 'idea' for a while to put a small 4 cylinder Diesel into a Bronco II. I've seen it done on the Early Broncos (non full sized) , the guy I saw used a Cummins 4BT out of a Bread Truck. I was wondering if any of you knew of an alternative to this, if any. :dunno
Travis
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
There should be alot of Isuzu or Kabota small diesels around. They are used in alot of industrial or commercial applications. We have a couple at work and they run forever on a gal of fuel.
On another Forum a guy put a 4BT in a 1970 Ford F-250 and it is sweet.
the 4BT fits nicely in the engine bay on a Bronco II I've seen quite a few in explorers over the years. visit www.4btswaps.com for plenty of information, the name can be misleading because there are plenty of other engine swaps over there it is essentially a diesel engine swap board.
The 4B and specifically 4BT or 4BTA are rather prized engines and are popular for swaps. The ease of the 4B engines is that transmission adapters are readily available for common light duty transmissions where some of the other small diesels do not have the transmissions support without custom machine work.
x2 :sweet
Stroked68
This is FORD Country
Eudora, KS
We had a guy stop by our house to buy a camper shell from us and he had a mid 90's 4x4 ranger with a 4bt in it. Sounded really sweet. Plenty of power for a ranger or bronco II.
