Removing Emblems - Best Technique?
RandyH
Western Colorado
What's the best method to remove the F350 fender emblems on an '05? I read somewhere previously that some use fishing line to cut the adhesive loose? Does that work easily? Also, does an '05 have alignment posts behind the emblem? Thanks.
nascar_fan28
IL
yeah.. just painted all my badges.. took them off with finish line.. and heat gun. the used a rubber eraser wheel to get rid of all the glue.. or sticky stuff..and yeah all badges have holes.. not the powerstroke tags.. but everthing else.
morningtoforget
Goose Creek, SC
you can also use a 2 or 3 inch putty knife then an eraser wheel to remove the double back tape holding them on. then a cleaning solvent (wax & grease remover or lacquer thinner) to remove and left over residue
RandyH
Western Colorado
Thanks for all the feedback from everyone. Most of the black in my fender badges is worn off so I'm replacing both sides and my grill oval that is peeling. Bad year for badges. Thanks again. :hail
use the plastic kind so you don't gouge the paint..
paint & trim supply shops sell a plastic spatula for doing this..
nascar_fan28
IL
grill is easy to take off too.. just take 4 screws out of top.. pull it back lilttle bit, and i took long flat blade screw driver to push clips loose at bottom.
RandyH
Western Colorado
Thanks Nascar. I hadn't even looked at the grill on this one yet. I had my '99 figured out but I haven't had this one off yet. The parts just arrived today so I'll get them on this weekend. If anyone ever needs OEM replacement emblems or any other parts, go through the socaps.com website and get a price from Sunrise Ford in Fontana, CA. I probably saved $25 buying through Sunrise (including shipping) instead of my local dealer. Sunrise gives socaps members a special rate. Dealer here wanted $36 for the grill oval and I got it for about $16. :clap:
Bolt
Plainview, Texas
Yup, 05's were bad for badges, I've seen allot of them peeling. I had mine replaced before I had 36K, under warranty, but didn't do the grill oval, didn't look bad. Now it does, I'll do it myself.
