rear lift help??
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Sounds like you only have a 2inch block. The bottom one that wraps around axle is welded on and is a spring perch. You won't change angles enough to notice buy replaceing with a 4inch block. You might need longer u-bolts.
Kinda yer call.. I'm an Air Bag fan.. more options for various load weights & balances. f100Cleveland makes good points about minor block height differences though.
SDChris
ont
For sure! I am going to look into the airbag system.
I sure wish that I had spent the exter $300 buck and got the air bags for mine. Good luck.
jarrburg
