Question Radio
RogerR
Colorado Springs, CO
I want to remove the 6 disc radio from my F350 to try to get the 2 stuck CDs out. It has 4 holes, looks like you should be able to push pins in and pull radio out, don't work that way, any ideas? thanks Roger
Smoky
Mississippi State
Thats the only way I know to get it out. Are you sure your push pins are the correct length?
RogerR
Not sure what the length should be, I made mine from 2 welding rods that just fit the holes and shoved them in until I heard them click, then used 2 small screw drivers as prybars. It feels like it is unhooked but it will not come out. It has me stumped, I don't want to break anything.
drmjf
Pinole, Kalifornia
Go to the nearest parts store and buy a set of ford radio removal tools. They are specially shaped to remove the radio.
it's stuck to the dash bezel..
use the radio tools to unlock it, then pul it forward bezel and all until you can get your hand around behind it.. a couple inches should to it..
push the radio out and the bezel back toward the dash
