Question Oil Cooler Blown!
tatt4u
Fort Worth Texas
My oil cooler has blown and wanted to find out what all needs to be done to get this done as good as possible? While in there I'm have it studded, egr delete, coolant filter, external oil filter, external oil cooler and 4 inch from the turbo back. My question or help I need is what o rings seals and gaskets need or should be replaced and anything else needs being done while apart?
Thanks for your help.
The factory head gasket kit is as good anything out there. I do not believe any other gasket set is better. I am assuming that you are referring to the 6.0 engine. It would be very helpful, for all of us, to have that information in your signature.
Dave :)
