Question OEM upfitter switches in older SD
Deerjager
Meister Gewehr
Forest City, NC
I was wondering if anybody on here had installed the newer model updfitter switch panel in the older Super Dutys? I have an '01 and like the look of the switches in the newer models. I rarely use the cubby hole provided in my stock dash for anything and would love to be able to put a bank of switches in there and use the space. Photos, comments, suggestions, how-to etc are welcome.:coffee
If you use our Search feature.. there's a bunch of guyz'n gals on here that have done just what you want to do.
just type in "Upfitter Switches" & go from there ??
Deerjager
Meister Gewehr
Forest City, NC
I tried the search in the audio/video forum and one other. I will check some others. Thanks.
AK Rover
Kenai, Alaska
From what I can tell by comparing my 2005 to my borther-in-law's 2003 you'd need to change out the lower dash panels in order to physically fit the switches in and have them look factory. As far as wiring I have no idea. On the 2005 and later it's direct plug in. No idea about earlier than 2005 trucks.
GCJB2002
delta bc canada
I put one in my 02 f250,i was a pretty easy in stall.I Put in the lower panel and ran the wires the way they came out of the 05 parts truck.
Geoff
