Nissan Titan/Cummins Engine
I foresee high maintenance costs... something else driving the hybrid market instead of the clean diesel.. Tier 2 Bin 2 emissions will actually clean the atmosphere as you drive..
dpantazis
#12
under the cheddar curtain
its about time! "if you build it, they will come"
first one out the gate with a 1/2 ton or a compact truck with an oilburner is going to gain HUGE marker share.
funny how the pictures smack of familiarity: cab off frame to access engine, the end of the motor is BURIED under the cowl.
they are aging talking about fuel economy in a smaller truck.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Agreed.
A 1/2 ton truck with say a spark-plug-less V-6 engine that has the grunt of a big small block or even a big block is so past due it isn't even funny.
I saw the cab-off problem right away and thought high maintenance costs. That could kill this project. I hope not as we need smaller diesels.
Dogman
tampa,FL
Well it did not kill fords cab off problem and they still have a lot of truck sold
dpantazis
#12
look at that market segment though. you have 3 choices- ford, gm/chevy and dodge.
the only thing going for the dodge is the cummins. the truck wrapped around the motor itself is blah.
the only thing going for gm/chevy is the trans. the truck wrapped around it is so-so.
nuff said there.
the odds of pulling the cab off are pretty low for any one individual.
Stroked68
This is FORD Country
Eudora, KS
Put that lil cummins in a Ford and you really got somethin. Keep the money for the domestic companies. I know probably Nissan is mainly made here in the states but the damn foreign companies are takin this country over. :rant
