Need to replace wheel bearing
BBT
only an egg
CA
Can anyone point me to an article or wiki on replacing the front wheel bearings? Never done it before. Special tools needed? Other parts to check or replace while it’s open?
BBT
bigrigr
Real trks hv 3 pdls
provo, utah
Depends on which wheel bearing it is. Some special tools needed for both the front and rear, just not the same tools. give us a little more info, why do you need to change it? :dunno
BBT
only an egg
CA
Noise, a rhythmic grind coming from the front left. Most noticeable when I let off the pedal and coast, can’t hear it too well when it’s rev’d up, though I can feel it through the bottoms of my feet. First noticed about 100-150 miles ago. I want to get it fixed tomorrow.
D-60 with manual hubs.
Thanks,
BBT
the only special tool you'll need is a 4wd retaining bolt socket. Tell the guy at any parts store that you need the tool to remove the bearing retaining nut. it will be either a 4 or 6 pronged socket that is around 1 3/4" diameter according to pirate it is Napa #775-9025
Autozone & the like usually have it as a loan a tool. Make sure that you replace the races while you're doing the bearing replacement.
bigrigr
Real trks hv 3 pdls
provo, utah
Don't forget to check the inner needle bearings inside the spindle as well, the axle shaft spins on these in 4wheel drive, if you in that far to do wheel bearings, you would be time and money ahead to at least check them and the axle u-joints as well. Most of the time the needle bearings only need to be regreased. A spindle puller makes this job a snap if one is available, but it can be done by whacking the spindle with a rubber dead blow hammer to free it up from the knuckle also. Imo ;tu
pjwoolw
San Ramon Ca.
If you have the automatic locking hubs it's completely different. If somebody doesn't come up with a how to ALLdata is an option for some good info at a reasonable price.
Bigrigr has the right idea. Replace as much as you can while your there. Pivot bushings will be a snap while it's apart. In fact check all the spring bushings too.
bigrigr
Real trks hv 3 pdls
provo, utah
Another thought, Somebody correct me if i'm wrong, but I believe that the dana's had the two wheel bearing nuts w/lock ring? if so you have to be really careful about putting the nuts/lockring back together on reassembly, or your wheel bearing won't stay tight.:eek:
NJKen
Is a proud new daddy
central NJ
+2^^
Ken
BBT
only an egg
CA
Thanks to all.
Got it done and it’s running quiet and smooth again.
Went to NAPA to get the parts and ended up having to buy the hub nut socket, couldn’t find a rental anywhere. It was $52! Oh well, at least I have for the next time.
BBT
