Question My truck sucks at towing, and here's why
Dogman
tampa,FL
The sticker on the door jam will have the other info. I think cold psi is 65 f-250. F-350 are 55 psi front and 80 psi rear on E range tires. But you also need to make shore your load on your tires are a E or F range. D's are fine if your not pulling heavy load all the time. But you will have roll in the side walls.
