Misfire Code poped up PO308
sierra4x4
California
Been a long time since posted.
2000 SD4x4 stock very low miles.
I wonder what is causing this code.
One thing I have noticed is the truck usually starts quickly and now sometimes I have to crank then turn off the ignition and crank again and it starts normally.
any help would be great.
Sorry I did not see the code in the title. P0308 is Cylinder 8 Misfire Detected. Sounds like a bad injector.
Autoenginuity will tell you this, but I am not sure about the others. Yes, most professional scanners should tell you this. A cylinder contribution test is another.
Dave :)
sierra4x4
California
Thanks for the help.
By the way IF i remember correctly the Cyl contributions test fails because of the crank sensor warranty replacement that ford installed for free.
Dogman
tampa,FL
The other thing is check the wiring harness going into the valve cover. The 7.3 had some problems with the wire clip busting and giving a skip to the motor. The down side is you still have to pull the valve cover anyway. Dorman sell a new update fix for this problem.
