loud clunk from motor when turning engine off, dash fues blowing
arrowstrap
BioMechanic
wa
been noticing it louder than ussual. most of the time when i kill the enging there is a loud clunk as the motor stops. sometimes it is a normal quiet shutdown. any ideas? also my dash fuse keeps blowing after a day or so. i loose rmp, fuel and batt readings. didnt notice anything out of sorts under the hood...
Dogman
tampa,FL
He says he has a HD TC. So I'm thinking flywheel loose or converter bolts loose. Could be a bad converter or trans pump.
....... or the Down Pipe hitting the firewall, or p-side heat shield... depending on >Where< the 4X4 truck gets shut down ? (frame flex)
arrowstrap
BioMechanic
wa
automatic.
it sounds like it is up front in the motor. i had the tranny rebuildt last year. i will have it checked. it is intermittent. i remember it used to make a compression sound like woosh. it never makes that sound anymore. when it clanks it is extreemly loud.
Dogman
tampa,FL
Check the starter make sure the starters not come loose from the transmission housing
arrowstrap
BioMechanic
wa
just an update... the dash gauge fuse blowing was due to the overdrive button wire rubbing on the frame at the base of the shifter. repaired the exposed wires and re routed it so it will not continue to rub when shifting.
arrowstrap
BioMechanic
wa
still loud clank on shutdown. very random. cannot duplicate at will. checked for loose exhaust or anything else but cannot pinpoint it. sometimes its a light clink and sometimes its very loud. I was able to catch it on video. please advise as this has me very worried.
https://m.youtube.com/watch?feature=youtu.be&v=RgWwBhfQFbk
79jasper
El Paso, TX
I would almost say cracked flywheel. Seems real common.
Sent from my *******-SM-G890A using Tapatalk
