Help Needed HELP with trailer charging!!!
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
OK I guess I will get under the truck and check out some of the connections. Thanks guys again. :sweet
I just remembered this when you commented about crawling under the truck. IIRC there is a ground wire attached to a bolt on the truck's left frame rail, about a foot ahead of the rear bumper bracket. It is the primary ground for the trailer connector. Take the bolt off, inspect it and ensure everything is clean and making good contact.
(xantrex 1000W inverter/charger)
Have you checked out the xantrex to make sure it's working like it should.
On one of the RV forums I am on there has been lots of trouble with this brand.
Xantrex has been buying a lot of smaller inverter companies, so they maybe just be getting in control of the former companies management. It takes time.
