Getting Closer (TT first time use)
Finally got the title to our Gulfstream Cavalier TT (aka a FEMA TT :D) today. Went straight to the courthouse and got a tag for it today too.
Finally legal and itching to use it. Need a little help on some pre-use tips, info, etc.
I know I will get lots of good advise, can't wait for the tips.
Let's go RV'n boys.
I am always in the mood for a camping trip. Just got back from one last Friday. Went to North East Arkansas for
a few days and after all of the flooding I couldn't get home, so we just stayed 7 days tell some of the water
went down. Some call it camping I call it home. Hope you have many good camping trips together.
(Need a little help on some pre-use tips, info, etc.) If it is a FEMA trailer, then put all
new tires on it and clean and pack all of the wheel bearing and clean the break shoes
and magnets on each wheel. Make sure each wheel has power to the brake and magnet.
These trailers have been setting at the Hope Arkansas Airport for the last 4 or 5 years.
Make sure rats didn't chew into any of the wires or water lines in the RV, does the
water heater light and work good, does the fridge work on gas and 120V?
X2 with Doug
Summed up ? After you check everything out.. Do an "Overnight'r".. at the house..as if you were at a Campground/Rv park.
Let us know of any issues ?
IIRC your "Rig" doesn't have Holding Tanks, yet ? If not.. you may want to check with the Campground/RV park you plan on going to.. Even though they have "Hook-ups".. ( buy Law & local ordinances) many places [Require] all Rigs.. to be Self Contained and Sustainable, i.e.: Black water, Grey water, Fresh water Tanks ?
Yes on what Joe said, I had forgot that most of these don't have tanks on them. Waiting to hear from you BAMA. Sure hope yours has tanks, because they are not cheap to have installed.
Towed the trailer home over 300 miles from where I picked it up. Tires are brand new, brakes worked well all the way home. All the lights work except for the porch light. Tried a new bulb, but still doesn't work, so gotta go deeper. Already ran A/C and it was Crummy cold. Fridge is electric only, I think. Haven't gotten the propane tanks filled yet.
How can I check to see if the fridge is propane too? Gotta get a break away battery for it too.
Gotta get it hooked up with some water to see how everything works in that area. And it does not have holding tanks.
What Brand of Fridge is it ? is it built in ? or stand alone ? If it's not built in.. it's most likely just electric (115v)
Without Holding tanks.. you might be hard pressed to find a Campground that will accept you :(
What kinda connections are there, on the out side, for the toilet, shower & sinks
Some Pics would sure help Bama.
Dogman
tampa,FL
I dont think FEMA trailer came with gas fridge. There all house units I think.
The fridge is a full size fridge and is bolted to the wall. No way to take a picture of the bottom. So I am pretty sure it is only electric.
I will take some pics Joe. I have seen plenty of FEMA trailers just like mine at our local state park. Can't go there anytime soon though, the tornadoes of 2 weeks ago really did a lot of damage.
Prolly is only AC then.
The acceptance thing is just based on my experiences RV'n 'round the country Stephen, it varies from State to state, County to County, Park to Park.. but No Holding Tanks, Is something to be considered (?) as You travel around ?
Until you address the tank(s) issue.. you could use a Portable tank ? One good web source for sizes.. and Everything RV for that matter, could be: campingworld.com.. along with yer local RV guyz ??
