Gauge wiring
4drdually
Wrench Head
Yardley, PA
Here's a shorty. I believe this belongs here. For you wiring up your gauges, a better, and much simpler way of running the wires to your pyro and trans is through the automatic shifter hole right inder the pedal. Follow the black line right down with your wires. Put a small slit in the rubber with a utility knife, and run the wires through. The autometer pyro probe actually has enough braided stainless wire to reach inside the truck when you drill and tap te hole in the right place. The wire that goes to the trannycan be zip tied down the shifter and drop off right at the place for the probe. This is a MUCH simpler and cleaner way of running the wires. Eliminates running 2 wires down alongside the header.
Dan
Northeast Texas
yes sir that where mine go for the tranny and the pyro, it was like it was made for passing wires :D nice and neat and easy to secure
