Fusible link terminal box feeding power distribution panel?
Cattflight
Washington State
I've got an '02 F350 7.3. There is a small black box on top of the left fender in the engine compartment that seems to house a thermal connecting the battery to a fusible link and then feeding the power distribution panel (fuse and relay box) on the cabin side of the firewall. The connection for the fusible link side has deteriorated and killed power to the entire truck. In the process of removing the terminal/junction box, it merely disintegrated into plastic bits. I have come up empty looking for the replacement parts since this doesn't seem to be listed in any parts diagram but I've seen people mention it in other forums.
So I have 2x questions:
1. Does anyone know what this item is called and/or have a P/N for it?
2. What size fusible links are these? I figure I'll put in a new set of fusible links with the ring terminal already attached. The battery cable looks like a 2awg or 4awg
Photos attached.
Thanks!
