Fuel pressure decrease wot
BioMechanic
Installed analog fuel pressure gauge. 50 psi idle. Uopn throttle decreases to 20psi. Cleaned fpr screen now idles at 40 psi, throttle 15-20psi. Need help. Need fuel pressure.
79jasper
El Paso, TX
If you have the money to do so, go efuel.
Otherwise you could have a weak fpr spring. You could try the bb mod.
BioMechanic
okay, just installed BB mod. now 60psi at idle and does not drop below 40psi WOT.
i guess my question is should PSI drop WOT? i would assume it would increase with throttle. more RPMs = more cam rotations = more fuel from mechanical fuel pump... right?
Not really. You have maximum flow at WOT and that will cause the pressure to drop. Fuel pressure may come up a bit as RPMs increase.
Artpro
Salem, OR.
Newby here. Pray tell, what is the BB mod??
40 psi at WOT sounds about right. These engines do not make more pressure at higher RPMs. Faster fuel flows = more resistance and less pressure.
By the way, :welcome Artpro!
