Evo Data Streams w/ chip
roosterdiesel
Earl needs B100
Amarillo,TX
When I have my DI chip in, I start to get tranny fluid temp and line pressure readings. :confused: There are no sensors right?
When I had a TS chip and when I upload the Evo they go back to 0 LP and 372(Edge says is norm)TFT.
Any ideas?
morepower02
Minnesota
Rooster, the line temp is set by the chip programer. It sets the firmness of the chip. David showed me in person all of the things that he can do with his equipment. Even let me play with his top secret laptop computer :sweet I think that he could make the horn honk when the truck shifts if you wanted it to :roflmao It is just in the tuning and is not a couse for huge concern :)
roosterdiesel
Earl needs B100
Amarillo,TX
:confused: I have a manual tranny, see sig. I thought I had programs for a manual PCM. Why would he play with that when the tranny doesn't have it.
The line pressure reads 5psi at idle, get on it shoots up to 175+ sometimes before I shift gears. Temperatures go up and down also as if it were reading an actual sensor. :dunno
