Question EGR/DPF Delete
Davesz06
Butler,Pa. USA
Anyone done an egr/dpf delete to there 6.4? My buddy has a 6.7 Cummins that he unplugged the egr plug and says he getting 3-4mpg better.I'd like to try that on mine but don't know about doing it on a 6.4.:dunno
MURR3061
ct
i can tell you you have 2 egr valves, and you will need a tune for it. i know SCT offers egr and dpf delete tunes. and Welcome to Elite Diesel Engineering offers custom tunning for this as well. havent been brave enough for the EGR delete thing yet, but let us know how you make out, i have been itchin to try this to, but you first!!!
MURR3061
ct
sorry
i stand corrected on the 2 EGR valves, there is only 1, thank you dave for correcting me there are 2 egr coolers, i havent messed with this yet, but i am pretty sure the tune is needed. this this is a driving computer. below is the text version of the
System Flow
• Air enters the system through the air filter where particles
are removed from the air. The air filter has a filter minder
on it to warn the operator of a restricted air filter.
• After the air is filtered, the mass of the air and temperature
are measured by the mass air flow sensor (MAF) and
the intake air temperature sensor #1 (IAT1).
• The filtered air is then directed past the crankcase ventilation
system where crankcase vapors and fresh air are mixed.
• After mixing with crankcase vapors the fresh air mixture is drawn
into the low pressure turbocharger compressor then the compressed
air is sent to the high pressure turbocharger where it is further
compressed before being sent to the charge air cooler (CAC).
• The (CAC) cools the compressed air via an air-to-air cooler,
then the condensed air passes through the EGR throttle, mixes
with cooled EGR gases, then enters the intake manifold.
• The intake manifold directs the cooled air to
the intake ports of the cylinder heads.
• The burned air fuel mixture is pushed out of the cylinder into
the exhaust manifold which collects the exhaust and routes
it to the high pressure turbocharger’s turbine wheel.
• The exhaust up pipe, connected to the passenger side exhaust
manifold has a passage that directs exhaust to the exhaust
gas recirculation (EGR) coolers and then to the EGR valve.
• The EGR valve controls the flow of exhaust into the intake
system where the gases are mixed with intake air to
reduce NOx (Oxides of Nitrogen) emissions and noise.
• The hot and expanding exhaust gases that are routed to the
series sequential turbocharger turbines, spin the turbine wheels
through flow and expansion. The spinning turbine wheels
then spin the compressor wheels via common shafts.
