Question Dino - Syn-back to dino...
icarus
Santa Rosa, CA
Anticipating going down So, as in waaay So for a while and am wondering what the scenerio is regarding going from the dino engine oil I'm using now, to syn for the longer life span, and then back to dino if I can't get the syn down there.
I'm running the Amsoil bypass by the way.
hheynow
Señor Aceite de Soja
Northern California
I went from Delo 15W40 to Redline synthetic 15W40 then back to Delo without a problem. Synthetic is compatible with dino so if some residual oil is still in there no worries. I have the OilGuard bypass by the way.
MJ Synthetics
So Calif
Yes going back and forth is not an issue. You may do that with no ill effects at your leasure.
