Diesel Site 203* Thermostat
Tman123
That One Guy
Murray, Utah
Anyone here running the 203* thermostat?
I just bought one and just wanted to know if switching from stock (I'm assuming is 180*) to this does actually increase MPG and doesn't cause my truck to overheat during the summer (which here in SLC, UT can reach 100+).
Thanks in advance!
Travis
I've been running one for 10+ years now. Temps are 20 to 105+ 'round here (CenCal).. Pulled our 5r all over the lower 48.. with Absolutely No issues.
No MPG gains to speak of.. but IMO, a Hot(er) diesel, is a Happy(er) diesel. Runs & Pulls better.. Overall ?
IIRC, Dieselsite has a good Blurb about Tech benefits ?
If yer guna drain the coolant down, to install the 203 thermo ? Now, might be good time to install a Coolant Filter too ? I'd step up and say: It's one of the BEST, Long Term.. PM things you can do for your (any) engine.
If yer guna drain the coolant down, to install the 203 thermo ? Now would be good time to install a Coolant Filter too. I'd step up and say: It's one of the BEST, Long Term.. PM things you can do for your (any) engine.
I would second this information! I have had a coolant filter since 12,000 miles. Great addition!!
Dave :thumbs
RSG
Savoy IL
x2 for Big Joe, and x2 for Dave Ben's advice. I also run the 203 Tstat hot or cold. I can assure you it will help with cold temp MPGs...
JimmyDee
God Bless America
Western Michigan
I have been running the 203 stat for several years. Sure turns the cab heater into the best heater out there. I do wish I would have purchased the higher priced aluminum housing. Mine is looking a bit not so good.
Jim
X2 on the Heat ;tu
I painted my OEM housing with some High-Temp black BBQ paint.. seems to be holding the rust & corruption back :dunno
Tman123
That One Guy
Murray, Utah
Well I installed it the other day (Saturday) and had to replace the T-stat housing because mine was stock from 2002 and was rusted almost completely through. lol
Travis
I also have had the 203 thermo on our 7.3L for close to 10 years also have the aluminum housing installed, gotta love the much toastier heat during the winter!
