Damage to Truck with Spartan Tuner
kctimmay
United States
Hi everyone. I'm a new owner and so far I am loving my 09 f350 SRW.
I've done a lot of reading in the past few weeks about the gains people have seen both in HP and Fuel Mileage with the spartan. My question is has anybody seen any damage resulting from these huge hp boosts. It seems hard to believe that damage to the powertrain/drivetrain doesnt occur. I ask this question because the knowledge you all provide is great and i'm really wanting to get one of these things.
Stroked68
This is FORD Country
Eudora, KS
Well you can do damage to anything with high hp without doin internal mods to your motor. The stock motor is built to last a very long time and be effiecient. We all know on the 6.0's that higher hp mods CAN blow headgaskets. I dont know much about the 6.4's or seen a lot of people do other mods to them. If you dont overdue it with the tuner, I'd say you would be ok but make sure you have gauges for monitoring your vitals. Thats one step into savin your motor. Someone who knows more about the 09's will chime in im sure.
koa187
phx/az
Yea im in the boat as you. I just picked up my new to me 09 f250 6.4 superduty 4 weeks ago and lovin it. waiting to see more replies from the pro's.:sweet
Bad Night
Uniontown Ohio
Modding your truck with any ones tuner could cause issues . It most likely will not but allot of that depends on you . Definitely get some gauges , egt , trans temp , boost at least . These guys that do the tuning spend a ton of time getting them right . You would most likely be fine but like any other power increasing mod you are asking more of the motor than intended so just use your head , run the pee out of it every day , you will most probably break something sooner than later .
On a side note a dpf delete and a tune on the 6.4 actually gets rid of a few problems that the trucks have . They tend to have regen issues and get allot of fuel in the oil . Make sure you do oil changes and fuel filter changes regularly .
Digital Oxygen
Got Boost?
Rockies
Your marker lights fell off. Slow down! :D
As it's been said before, yes, you can damage any motor with any tuner. The Spartan tunes are all decent, in my experience. Of course, once you get past the 250? 275HP tunes, and over 55PSI of boost, you really ought to consider things like EGR deletes, wastegates, and maybe even a Blow off valve.
You'd never believe how quickly you can slam the compressor blades shut when you instantly take your foot off the go-go pedal while pushing 50+ PSI.
If you do get a tuner, just use your head. Don't drive around like a jackarse, flooring the truck at every light and you should be fine. If you are running higher HP tunes, I really recommend EGR delete, wastegate, ARP studs and even a new updated headgasket. well, two of them.
koa187
phx/az
I was thinking of doing that but whats the deal with deleting the dpf? And will it void my warranty? My truck has 18k miles on it. Also i heard some where about a fine from the feds if its removed? Any body know for sure in the AZ area? thanks
alldaysports
North Dallas
was wondering the same here.
Bad Night
Uniontown Ohio
Yes , It will void the warranty (as will a tune with most dealers) but you can put it back and remove the tune before dealer work . It is illegal as well but so is removing the cats on sports cars and everyone does it . The chances of the feds getting under your truck are slim to none .
hetner1102
Austintown, Ohio
Tuners
I have the HandS on my truck with the DPF delete an five inch mag afpoe. I only use it on the mild setting and what a difference, mileage in town unloaded is 15-16, and highway unloaded is 21-22. I pull a 40 ft fifth wheel and still get 16-17 on the highway. As far as leaving a footprint, HandS says theirs is the only one that does not leave any marks on the stock ECM. Good Luck
