cooling fan issue
gtm dude
lawrence ma.
I recently noticed that the engine cooling fan has been coming on and off at odd times. in the morning when it's cool it may be on for several miles and then disengage. then may come on again with an ambient temp of 80 degrees. last year in Tampa in august I barley heard it. The two codes in it are po 480 and po 528. The truck is a 2006 F350 super duty diesel. Has anyone else out there had that problem, and could you please advise. Thank you
P0480 is a Cooling Fan I Control Circuit Malfunction and P0528 is not defined in our WIKI Technical Articles in the TOP BLUE LINE above. You have a cooling malfunction causing your fan problems. By the way, :SDD Dude.
castellscl
