Question Coolant Filtration System filter replacement
NASCAR Mike
Richmond VA
I am using the Dieselsite Coolant Filtration System and I am ready to change the filter.
I only bought two filters at the time. Can you use a standard oil filter instead of the $11 one they charge at Dieselsite?
If so, what is the model # of the oil filter? It looks like a Fram PH8A or Motorcraft FL-1A.
Zmann ARGH
AZ
those you listed are oil filters ,, atleast go to napa and get an uncharged coolant filter
I'm sure someone nows the PN#
and they are about 11 dollars lol
Coolant Filter #
I Have Bob's coolant filter set-up too. I use a Baldwin, B-5134.
