Question Battery's
IDSTROKER
Blackfoot ID
Blackfoot ID
Hello everyone it's been a while just been busy. Ok i noticed that my tk has been turning over slower when starting so i used a battery tester to check battery's so i unhooked both battery's tested the drivers side when we hooked it up it showed 12.8 v hit the test switch it drop to 12.4 v this battery good passenger battery hooked up 12.6 v hit the switch needle went to 0 v battery no good. BUT hook battery up only the passenger side and the truck will crank over and start so is this battery good or bad..:dunno
1 good battery and 1 weak battery, wired together (in parallel) will create a weak combination.. for Start loads.
1 good, or 1 weak battery may start the truck.. but not long term.
Always been my take on it, with these high compression diesels :dunno
If it checked weak.. it's weak.. and needs to be replaced. Rule of thumb ? Replace the Both.. with a pair of batteries built at the same time.
You might wana retest them after they set overnight.. so any Surface Charge has dissipated... from any running/charging you've done today.
That's the Real Deal.. as far as load test results go.
IDSTROKER
Blackfoot ID
Blackfoot ID
well just got back had someone else test them and the passenger side is shot has dead cell. Going to get 2 new batteries. Thanks big joe for your input..
