? about the CCV Mod.
ForumBlue said:
Where would I find the 4"od x 3-1/2" long steel tube?
And
What is the black thing to the right of it in the picture?
you should be able to pick up the tube at your local hardware store I know that the local Ace hardware will cut to length and sell you whatever length you need I'm almost certian that you'd need to buy a foot or so but black iron pipe is what I am pretty shure you're looking for. Home depot or Lowes would have it also but you'll endup buying quite a bit of extra from them.
And
The black part to the right of the 4" x 3.5" tube is the factory CCV collector which is what gets replaced.
The 4" ID tube you can get from most big truck shops that does exhaust,an alternative is 4" ID pcv pipe.
Bill
whatabudro
Launched
Bill
I know nothing about the mod ya'll are talking about, but any electrical supply house will sell you a 10' stick of electrical metallic tubing (EMT) and its already galvenized.If you go this route though take a tape measure, electrician's go by ID so 3.5" is 4" in the rest of the world, and is actually 3.8" with a tape. If you were close I would simply "hook you up", but a 10' stalk of pipe, will work for other things on our trucks, such as exhuast repair. :cool:
