94 IDI stalling out
Txwelder
Dallas, Ga
My Dads truck will die sometimes for no reason. It has to sit for 20 min or so before it will start back up. He told me that he tried to drain the F/W seperator and nothing came out. Is the LP electric or mechanical? Any ideas? Thanks.
:welcome3 to SuperDutyDiesel, Txwelder. This truck is very simple. You have fuel or not. Your fuel filter can become clogged, as can the Water Separator. Take them apart and clean them out and see what happens. I will bet it will start. The pump on this truck is mechanical, like a gas rig.
94f450sd
certified nutjob
plymouth,ma
how many miles on it?when was the last time the injection pump was replaced?usually when they stall and wont start hot is the IP.when they get hot the clearances are too loose and it looses pressure
Wingdog
Thunder Bay, Ontario
I second the fuel pump. Throw a new fuel filter on it and if you can't get it to squirt fuel out of the bleeder valve then its time for a new pump.
