4x4 not working P1820
sagebel
Stock? Pfft!
Albuquerque, NM
While looking for my miss I got a P1820 code yesterday. Truck will not shift into 4H or 4L. Checked a 30a fuse under the hood and two relays under the hood. If I ground the relays the motor will shift so I think it is in the GEM or the dash switch. How do I narrow it down?
ha ha ha..
you're in luck..
shoot me an email and I'll send you a PDF of the circuit.
that setup is a lot more involved than you'd think.
to start with, you need good fuses at positions 19, 13, 28 and the 30 amp'er in 17..
sagebel
Stock? Pfft!
Albuquerque, NM
All fuses are good. Disconnected the switch and all switch position resistance matches the figure. Does this mean I'm looking for a GEM?
sagebel
Stock? Pfft!
Albuquerque, NM
Started ringing out each wire to the GEM module today. The brown/white wire (low to high control) has no continuity between the relay and GEM module connection.
I have a questin about the 4x4 module. The diagram has a transfer case shift module. I thought the 2000 trucks just have two relays under the hood. If I do only have the two relays, I think I found the problem.
yes, I'd say the open wire is the problem..
that wiring diagram is actually for a late 99 (my truck), so component locations might not quite be the same, but I knew we could get you going in the right direction by showing you how the circuit works..
check this thread as well
http://www.superdutydiesel.com/foru...-4x4-light-does-not-come-all-help-please.html
sagebel
Stock? Pfft!
Albuquerque, NM
Fixed it. Brown/white wire is broken somewhere in the harness. Ran a new wire and 4x4 now works. Now back to the miss. Thanks JL for the diagram.
