2005 f350 superduty diesel issues
superduty13
chandler, az
I bought my truck in 2006 for work, take good care of it a year after I bought it I had some issues with the turbo they ended up replacing turbo, EGR valve and cooler, and since then I have put in a new alternator every year after due to a pwr issue. I have put a lil under 100,000 miles on it since 2007 well guess what same problems again, white smoke and stalling and lack of power I got it hooked up to a diesel diagnostics and it shot me the following codes> U-1900, B-1317, B1352, P-0326, P-0341, P-0404, P-0672, P-1379, AND P-1335 The diagnostics guy tells me a new erg cooler and valve, an oil cooler, a possible harness and FICM and alternator, i know that some things being replaced may fix others so please help.It is killing my business for my baby to be down
We have a list of the DTCs (Diagnostic Trouble Codes) in the Technical Articles WIKI Section in the TOP BLUE LINE.
Some of these codes, P1379 and P1335 are not shown in this table or in another chart I have. The U code is not shown nor are the B codes ( they are for Body ). The U code is a network code for your truck's computer system. This all sounds too messed up. P0341 says to replace the CPS (crank Position Sensor). It also states that there might be a ground problem. I beleive this and the rest are all part of a general grounding problem. Check your grounds for being clean and tight. Good Luck.
