2002 f350 Power Brake Booster
uloadit
Swansea Ma 02777
I am starting to get a leak inside the cab of the brake booster . is this the booster or the master cylinder ??? if it is the booster can I get a rebuild kit ? if not where can I get a relatable company that has one. thanks
Smell the oil that is dripping in the cab. That will tell you if it is brake fluid or hydraulic oil. BUY a rebuilt booster. Unless you have a complete shop they are too hard to rebuild.
Dave ;tu
uloadit
Swansea Ma 02777
:yeah I have a big shop .photo in my avatar. I build transmissions so I think I can handle something this small . ;tu
Neura
How do the brakes feel.. usually if they go rock hard and you can stand on them with 2 feet and barely stop it is the booster...
I have rarely seen a master cylinder leak into the cab on the diesel trucks.. pretty common around my area in cold weather that the booster starts leaking.
We usualy end up with cardone rebuilts in my area.. but someone may have a rebuild kit for it.
