What Gears?
cemily
Columbus, IN
I am trying to figure out what gears my truck has. On the sticker the axel code is blank. At 60MPH I am running 2000RPM. Please Help.
I looked last night and there isnt a tag there.
then someone REMOVED the tag...the only OTHER thing you
can do is look at the door tag...but that wont tell you anything
other than what the truck came off the factory LINE w/.
Have you owned the truck since new ?
cemily
Columbus, IN
No I am the third owner.
check the sticker in the door jamb for the rear axle code, we'll
help you decode it....but theres no way to be certain that door
code actually matches whats in the pumpkin'
cemily
Columbus, IN
On the door sticker the axel code is blank.
MidwestOffroad
MN
is the truck stock height and tires., what is the year and
single axles came with 3.73 duallys had 4.10
if it is lifted it may have been regeared..
a 32" tire and 4.30s would be turning 2000 rpm at 60
