Well my Tru Cool 4590 is here!!
Scar13
Little elm, tx
Anyone have any pics of a install they did??
Where they mounted and so forth?
I cant find anything on the net about it which is odd.
The install paper work that cam with it is lacking at best.
Ive got pics of my install but they are for the 94-97 model years. Its a snap to install.
Scar13
Little elm, tx
Those pic's help alot so it sitting against the radiator? Doesnt that posiistion block air flow to our radiator?
should be as simple as taking the exiting line from the stock cooler and routing to the Tru cool and then from the tru-cool to the tranny?
In the one pic it came with its sitting on a condenser I cant find..
I am goign to run mine in series with the stock cooler I hope.....
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I installed two aluminum cross bars horizontally between the verticle braces behind the grille. I used some spacers between the verticle braces and the horizontal cross bars. The spacing of the horizontal cross bars was determined by the mounting holes on the cooler. I mounted the cooler with the inlets on the side. Putting them on the bottom is bad because you'll get an air bubble in the cooler. Putting them on top was bad because of the way the tubing/hoses would stick up. I hooked it up so the fluid going into the cooler was on the lower fitting, filling the cooler before coming out the outlet on upper end.
If you still would like some pics, I can get the camera out.
