well its alive but dead again
94f450sd
certified nutjob
plymouth,ma
i got the replacement injector monday,installed it yesterday drove around last night and today putting about 100 miles on it.but once again my nice comfortable ride is comeing to an end tomorrow.its still skipping.passes the buzz test but the CCT says #6 contribution/balance fault in park but then it says #8 C/B fault in drive with the ebrake on.do the test again and it says system pass both times.run it again and it says #6 in park and #8 in drive.i have just about had it with this truck,the other truck and my cars.im about to load them all up and send them to the crusher.
every time i turn around there is something wrong with them.the only car i have that fires right up and runs like a champ is my old 66 pontiac.its been sitting without starting it for 6 months.i put a battery back in it and pumped the gas 3 times and she lit right off on the first crank as usual.
Well darn it I wish things would go better for you.
Do you have the stock injectors that came with the new/used engine. Maybe going back to stock and building from there would help pinpoint the problem.
94f450sd
certified nutjob
plymouth,ma
i do but they need orings and i dont even know if they are any good to begin with.
MUDWHISTLE
Diesel Lover
oregon
Oh man that sux rich, I feel for yah. I don't have any suggestions but I know how it is I have been there, I think we all have.
94f450sd
certified nutjob
plymouth,ma
the latest?how about i am so close to burning the freekin thing it aint even funny.i figured that since cylinders 6&8 came up on the contribution test almost every time i would swap them with cylinders 1&3.so i did.fired it up and ran the CCT again,came up with #2.so i let it run some more and did another CCT,came up with #2 again.so i was like great i found the bad one!!.called bean,got a replacement on the way.so i figured id swap #2 with another cylinder.pulled it in the and for the hell of it did 2 more CCTs.said system pass both times.the truck sits there skipping like a sick whore and comes up with system pass.:rant :rant :rant :rant :rant :rant i dunno WTF its problem is but im about to watch it go into the crusher and watch it come back out in a freekin cube!!!!!!
