weird "hiccup"
Tx_Atty
Master Baiter
Fishin'
today's oddity - driving home at steady 55 the truck all of a sudden jerks for just a split moment then continues normally. It felt and sounded like it cut out. I can't explain it well but it felt like I had run over something small but noticeable. I did not however. Could this be a CPS giving me warning? No other strange behavior on the rest of the drive home. :dunno
deereman39
Deereman
White Hall IL
Yes i had one do the same thing to me,it kills the engine for a split second,changed out CPS and all was good.
Cheers Ed :burnit
Keller, TX
Same here, Peter. The longer it goes, the more frequent the "hiccup" will occur, until it just quits. Mine was doing it about twice a week when I replaced the CPS. Haven't had it since.:sweet
hheynow
Señor Aceite de Soja
Northern California
IMO, it's telling you to get some B100 from Rooster ...:roflmao
jus' kiddin'
Yup, keep an extra CPS on hand, a 10mm six point socket, 3" extension and ratchet.
Tx_Atty
Master Baiter
Fishin'
I think your right Richard, it must be getting the DTs! I actually had a dream the other night about filling with B100. Guess I'll look in ebay for that cheap cps. great, another $100. This month has been expensive with little or nothing to show for it. Thanks for the input; this site sure does save mechanic costs!
roosterdiesel
Earl needs B100
Amarillo,TX
:roflmao ....DT's:roflmao I'm workin on it Peter!
When my CPS went out it hiccupped a couple times one week, the next week it died twice in a row. Restarted both times, good thing I was pulling into parking lot at work. Pulled codes and got the CPS code. I replaced it after work with no problems since. Went straight to International house and bought another one for the glovebox.:D
Keller, TX
Peter,
I got mine off E-bay for $50. You might just buy two for $100.:2c
goldhilljoe
S W Oregon
--- QUOTE "Yup, keep an extra CPS on hand, a 10mm six point socket, 3" extension and ratchet."
Great advice--should be a requirement for ALL 7.3 DI`s
Tx_Atty
Master Baiter
Fishin'
Antonio, what did International charge you? I have to drive to Abilene this weekend and cant get the ebay one here that quick. I noticed Joat's part page has an International one listed but I didnt understand the "above/below engine 375548" part.
roosterdiesel
Earl needs B100
Amarillo,TX
$89.98 + tax. I know someone that works there, they wanted $110 IIRC, he cut me a deal. "375548" is the engine serial number, I don't remember what year the change is, not sure really what the change is either.
