Don't remember where I got these instructions but they worked for me:
1. Partially drain the engine cooling system.
2. Remove the upper radiator hose clamps and upper radiator hose.
3. Disconnect the radiator coolant recovery reservoir hose at radiator.
4. Remove the fan and clutch assembly using the Fan Clutch Nut Wrench and Fan Clutch Pulley Holder. Set the fan and clutch assembly in the fan shroud.
5. Remove the fan shroud screws. (2 ea.)
6. Remove the fan shroud, fan and clutch assembly. I lifted the shroud up some and pulled the fan and clutch assembly out first then removed the shroud.
7. Loosen the four water pump pulley bolts.
8. Remove the drive belt.
9. Remove the water pump pulley bolts and water pump pulley.
10. Disconnect the engine coolant temperature sensor.
11. Disconnect the heater hose and clamp from the water pump.
12. Remove the water pump inlet bolts and water pump inlet.
13. Remove the water pump bolts. These bolts are different lengths. There are nine bolts and three different lengths. Mark where they go.
14. Remove water pump and water pump housing gasket.
15. Clean gasket surfaces.
Installation
1. Install the water pump and water pump-housing gasket. I put a little grease on the gasket to help hold it in place.
2. Install the water pump bolts, torque to 15 ft/lbs.
3. Install the water pump inlet and bolts, tighten bolts to 15 ft/lbs.
4. Install the heater hose and clamp to the water pump.
5. Connect the engine coolant temperature sensor.
6. Install the water pump pulley and start the water pump pulley bolts.
7. Install the drive belt.
8. Tighten the water pump pulley bolts to 12-18 ft/lbs.
9. Install the fan shroud, and fan and clutch assembly. Nice to have an extra set of hands, but I managed it by myself.
10. Install the fan shroud screws
11. Install the fan and clutch assembly using the rental tools.
12.Install the radiator coolant recovery reservoir hose to the radiator.
13. Install the upper radiator hose and clamps.
14. Refill and bleed the engine cooling system.
