Wandering truck and hissing sound
sagebel
Stock? Pfft!
Albuquerque, NM
The truck seems to be wandering quite a bit lately with a lot of wheel play. There is also a hissing sound (like when you slowly open a high pressure valve) when turning hard at slow speeds. Ball joints have about 2000 miles on them. 188,*** on the truck. Any ideas? I am thinking steering box but I'd like some opinions before I start spending $$$.
Scott
Frankenstien
Frankestien
South Prairie Wa.
The problem is.............. YOUR TRUCK MISSES THE NW.......
You may be suffering the same problems that I am, Leaf spring bushings are a bit work as well as the sway bar and others. I'll be looking at an "Energy" Bushing Kit soon for all four corners.
sagebel
Stock? Pfft!
Albuquerque, NM
We all miss the NW but that may not be a problem in Spring 2010. I'd like to get this fixed before that trip. My front leafs and bushings were replaced about 20000 miles ago. I am also planning on larger sway bars but not right now.
Frankenstien
Frankestien
South Prairie Wa.
Scott if you are seeing more than about 10 min of play in your steering wheel, there is an adjustment on the steering box itself. there is a worm gear screw adj on the top of the Box, loosen the retaining nut (pay attention to the clock position or the screw head) turn the screw clockwise adding maybe 5 min of position. Run the truck to see if this helped. I don't recommend going much more than 15 min of turn total. This should help in taking out quite a bit of play out of the box.
sagebel
Stock? Pfft!
Albuquerque, NM
Did that a couple weeks ago. No change. I also noticed yesterday that I can rotate the center link by hand. Is this normal? I just went over 190,000 miles yesterday. The steering gear, tie rods, center link, stabilizer, and ball joints were all new at 98K. I guess it may be time.
Frankenstien
Frankestien
South Prairie Wa.
Center link should be able to "Move"... but not typical of just hand pressure, usually you have to have a wrench on it to move it much. I'm about 2500 miles from that 200 K mark, still have the original suspension parts, thought they are getting tired, only things I've changed were the shocks. As I bought the Monroe's with a life time warranty, I change them out every 2 years, weather they need it or not.
Brad1103
