vacuum line identification help pls
Tx_Atty
Master Baiter
Fishin'
Im putting in my version of the AC mod with the vacuum solenoid. I have read all the posts here and the other place and my lines dont look like the ones described.
What I want to identify - a line that draws a vacuum for both vent and AC. Attached are some pics I have taken under the dash. I see a vac thing right under the data port that I watched operate under vent and AC but cant see a line to splice. There is a blue line to it but not enough room to work.
Going toward the passenger side there is a pair of lines, black and white, that go to a triagular thing with 3 "ports" on it - they take up two and one is empty. What is that and can I put my line there?
Also - the other end of the white and black lines meet up over the trans hump and go to a larger plug with other lines - yellow, red, blue. Also pictured.
I only need to "t" into one line that will create vacuum in vent AND A/C. Any input would help. See pics.
Thanks!
dpantazis
#12
under the cheddar curtain
Tx_Atty-
Did you look at rexaford's webshots montage? he has schematic there. since you are OBS, i dunno if its the same.
http://community.webshots.com/photo/70893242/1070893482033257109sPwejJ
http://community.webshots.com/photo/70893242/1070893474033257109coguwT
you might want to look at steve baz' pages- he is OBS for sure and his suggestion is white.
http://pages.prodigy.net/stevebaz/_import/pages.prodigy.net/stevebaz/index3.html
i am still working on getting the hole in the FW done and grommeted.
dp
Tx_Atty
Master Baiter
Fishin'
I had read Baz's but white is only for Max setting or Off. I want anything left of off. However, your link to rexaford's shows a chart and I think the black line will be what I need. It is vaccum all the time and my solenoid is what will control the water valve so that might just be perfect. At least the color chart lists the same colors I have. Cant be too much different. I hope.
Thanks for the help!
(if Im wrong, noone hesitate to set me straight!)
Tx_Atty
Master Baiter
Fishin'
I got the water valve installed and vac line run through the firewall, got the dash switch (lighted) mounted but not powered. I ran out of time before having to be somewhere tonight. Tomorrow I will mount and wire the solenoid and should be ready to test it out. I will make a write up if anyone wants to do the mod this way. Even if it is already installed, my version can still be set up. I need to take some pics.
