hheynow
Señor Aceite de Soja
I need to install a vacuum gauge to measure fuel restriction in my two aftermarket fuel filters even though the dash FUEL FILTER light and vacuum sensor on the FPR both work. I'd like the gauge on the dash in a pod but will mount it under the truck if absolutely necessary. Is a glycerin filled gauge mandatory? Should I install a tee in the fuel line under driver's door and mount the sender there? Should I do away with the vacuum sensor on the FPR and tap off of this port? Is it safe to use plastic tubing or is braided SS needed? The price difference is huge. I've heard that mounting a fuel pressure gauge inside the cab is potentially an oily mess, but is there this concern with a vacuum gauge?
