UPDATE:Cab light harness
happeetxn
9/11 Never Forget
Dallas
Howdy All,
I have my cab lights (marker lights) mounted and a harness made up but I am having a problem finding the factory harness on the passenger side. The only empty electrical connector I found didn't have power to it when I turned the lights on. Any help will be greatly appreciated.
See ya,
Craig
Edit Portion: Helps to make sure you don't have a blown breaker which would keep you from getting a voltage reading! DOHHHH!!!!!
Tx_Atty
Master Baiter
Fishin'
mine was behind the kickplate and had two holes in it vertically upward. Dont have a picture, sorry. the holes are in a plastic connector with nothing in it, side by side. kind of flat looking.
that should be the connector I think there is only one over in the passenger's kickpanel. You may need to double check the fuse box and make sure that the cab marker lights aren't on thier own fuse. Which would more than likely be absent in your truck wich did not come with marker lights.
