Ultra Low Sulphur fuel?
gilla
05, PSD, CC, 4x4
Mississippi
Must be in tanks by this fall. Do we need an additive for the 07 and older to keep pump lubed?
hheynow
Señor Aceite de Soja
Northern California
Adding as low as 2%-5% of biodiesel (B-2 B-5) will more than make up for the loss of lubricity in the new formulation.
ForumBlue
CDXX
Southern California
I'm assuming the PS i use will make up for the new fuel. Plus the current diesel will still be available until 12/1/2010 and probably cheaper than the ULSD at first. Using ULSD in 06 and earlier trucks may loosen some of the deposits in the fuel system so check the filters often.
Edit: I just read that additives to increase lubricity and inhibit corrosion will most likely be added to ULSD prior to retail sale. Here's the link.
ABC's of ULSD
