Tuner
brevelerib
Massachusetts
Im looking to get a flash from what I understand it comes pre programed and plugs into the plug under the dash.... Im not sure wich brand, Im not looking for an expensive one. I pull a horse trailer at times... Any advice, pros cons, new to the whole dielsel thing ....
Thank you... Cheers
NevrKnow
Aiken,SC
The problem with off the shelf is ...well.....they are off the shelf. Hard to get them customized for YOUR truck. For the same price.....you can get custom tunes that make your truck run the way you want it to. With off the shelf tuners you are stuck with what they have. UNLESS you have someone retune it, which means you'll be paying more for the same thing you could have gotten the first time around. Make sense?
