truck runs rough
hammy
Hey everyone. I have a new problem with my 99 powerstroke. When you let it sit for a couple of days it will turn over and fire then die. After a couple of times doing this it will fire and run very rough and no throttle as if there is a lot of air in the fuel system. Seam to be worse when facing up hill. Could it be a bad check valve somewhere in the system. Let me know what you think thank.
hammy
pump ok
I've checked pump clearence and all pressures everything is all ok. Anyother ideas is there a check valve on the return side of the fual system.
Have you replaced that QD fitting (?) on the in-let (Tank) side of yer fuel pump (??) with a piece ofr fuel hose & 2 band clamps ??? Sounds like air getn' into the system to me. That QD fitting is a place (of many) to start. Then the tank Mods..
When its parked Up-Hill.. you may be getting a Syphon effect going cuz of air being sucked in from that QD fitting.
:dunno
