F350 Poland Stroke
Lonely Polish Stroker
Hi Ford drivers,
on my 1994 F350 7,3 Powerstroke crew-cab-long-bed-two-wheel-drive-non-dually ia have a problem withe the transmission. Since 10.000 KM the transmission controllight starts to flash after a few driven kilomters. It starts mostly after shifting in the last gear (OD) or after i was speeding up with high RPM (2500 to 3000). When the light is flashing the transmission shifts usualy and without any problems. If i turn of the engine it is off after starting again and comes back a few kilometers later. I have a big transmission cooler installed and do not think it is because of heat. I do not know how to read out the code, please could you give me instruction to this?
next thing is, when i want to start on traffic light in D engine gives high RPM and car starts really slow, if i start on 2 it starts really quick. If i drive setting one till end it is the same like on setting 2, should it not shift one time one setting 2?
for an answer i would be really happy, here in Poland nobody knows about this famous trucks from Ford.
Kindly regards,
Janusz
F350 7,3 Powerstroke Crewcab Longbed, 286.000 miles, no changes from stock
Kindly regards,
Janusz
