Too many switches...
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
I have several things on toggle switches, and a couple POTs (EOT and 10K) i want to make a homemade AIC.... but i fear i am running out of room for all the switches:eek: and it is starting to look cluttered possibly too much wiring:confused:
What have others done to clean up a problem like this; ie, switch panels or boxes?
Thanks a bunch
Neal
I've seen the setups from AW direct and I like the basic design but they leave something to be desired interms of numbers of switches. Along the same basic design of the AW direct setup but with your own toggle switches installed and if you're not going for lighted then you can put a dozen or more switches over the cubby hole to the lower right of the steering wheel.
On a side note my biggest complaint about the switches that cover the cubby hole is not the loss of the cubby but the fact that when I go to remove that panel it's a real PITA to deal with all of the wires. Right now I have a switch mounted on that panel for the rear AC in my truck and I get annoyed with it though it is easy to reach.
If I ever put switches there I will find some sort of socket plug to put in there that will provide a quick disconnect.
94redbeauty
Pullman, WA
Anyone used that SWPF-14 that says for our year trucks off that AW site? I cant figure out how that mounts "above the cubby hole?"
