One of the challenges while using a RV is to store the septic hose.
I have come up with a cheap solution. This probably is not a new idea, but it is new to me.
That is get a 1/2 or 3/4 pvc pipe, just long enough to put through a compressed septic hose. Put a tee at each end of the pipe. This keeps the hose compressed and able to fit into a small area. I cut four two inch pieces of pvc to fit into the tee's so that the hose would not slip out.
Before cutting the pipe, just measure the length of the septic hose while it is compressed and cut the pipe a couple inches longer. Put one tee on the pipe and push the other end through the compressed hose, then install the other tee.
