Thermostat Neck Bolts
dboyw
Lancaster, PA
Hello again. After changing the water pump, and hunting down leaks, I pretty much rounded the three bolt for the thermostat neck. I have the Dieselsite billet neck, if it matters.
What bolts do I need to replace? I know I could take one to Homedepot, but I wanted to see if someone knows first.
Or would it be better to go to Ford and get the over priced bolts?
Thanks for the help.
dpantazis
#12
under the cheddar curtain
i would go to the hardware store and get stainless cap screws. i am pretty sure they are 6mm, but don;t remember the length.
make sure you use anti-sleaze on them whichever you put back in.
dennis
dboyw
Lancaster, PA
Yea, that's what I did. Took one out and to the store. Got three but I can't remember the size either, and it was only 2 hours ago.
Brad1103
